View the Local SA Cache
View the local SA cache to display the (S, G) state the router learns from local Protocol Independent Multicast - Sparse Mode (PIM-SM) entries.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select MSDP.
  3. Select the SA-Cache-Records tab.
SA-Cache-Records Field Descriptions
Use the data in the following table to use the SA-Cache-Records tab.
Name
Description
TypeInformation
Shows the SA cache type. The SA cache type can be local or foreign cache.
GroupAddr
Shows the group IP address of the SA cache entry.
SourceAddr
Shows the source IP address of the SA cache entry.
OriginRP
Shows the RP address of the SA cache entry.
OriginatorAsNumber
Shows the AS number of the originator.
RouteType
Shows the type of route used for Reverse Path Forwarding checking. The value can be rip (1), ospf (2), static (3), bgp (4), isis(5) or none (6).
